Maybe this is a national question but.. I see there are lots of MPSCS page site changes. Does it affect me in any way? Do they ever change the control channel? (which I think is all I care about?)
Does that matter what brand of scanner you have? Do you mean it scans 5% faster?I program all the freqs for sites because doing so increases scan time by less than 5%.
Pardon my ignorance but wouldn't it be better to monitor just the control channel and get directed to a talkgroup you want instead of checking all channels?
Some people prefer he "Belt & Suspenders" approach.Works for me
That approach works fine on P25 until the control channel changes, and then you suddenly get nothing from the site.It's always been my understanding when monitoring MPSCS in Michigan all you need to program the control channels. Works for me!
For NXDN and DMR trunked systems, programming all the frequencies and the associated LCNs is mandatory.
Sometimes I see things highlighted in GREEN in the database but when I look and check it against previous info I can't tell what was changed. Am I missing something?
KInda new (but not to Radios, or Scanning, just here and the technical stuff - I was wondering if you all (Krokus...is that from the Rock Band?) would advise what you use to scan (or would if you were getting all new stuff...preferably inexpensive but NOT cheap, want it to last ) and also would share some of the programming knowledge (without the acronyms) about what you scan, control channels --and since I am posting, where are the scanner archives of the scanner traffic (the main reason I am premium). Thanks in advance, k845rp
Software for what?Krokus (check out Headhunter- Live) Thanks. Yes I have seen that handheld. What software do you use (if placed online and to control via computer, assuming it is not the stock...I hack so just askin?
