That looks like a regular P25 system that uses bandplans.
Don't know what to tell you, it uses explicit entries for the VHF sites.
I wish I could direct you to the system type I'm talking about, but the one I knew of seems to have been updated to a Harris system.
The P25 frequencies had those little black numbers next to them like an LTR system so you knew which slot to program the frequency in.
Do you recall any of those?
I don't think I can search other systems, but other ones (if they still exist) are likely to be in the UHF Fedband.
I'm guessing if the system didn't support multi-block messages you could do it that way. Maybe it was some smaller manufacturer that didn't know how to implement multi-block and just did it the way you saw.
Greater Austin/Travis Regional Radio System (GATRRS) Trunking System, Austin, Texas
Greater Austin/Travis Regional Radio System (GATRRS) Trunking System Profilewww.radioreference.com
I've listened to this system a number of times on x36HP scanners. It's Control Channel only, if that helps clear up the confusion. Which I think makes it an implicit system. At least for the 700/800 parts. I've never listened to the VHF section so can't comment.
Is it possible to use different modes for different sites? That system covers a large geographic region, so a mix of implicit and explicit sites may be the only way to get it running.
As I posted the VHF sites are explicit.
I thought we covered this already in my earlier post?The thread posts seem to indicate that it's one or the other as far as how systems work. Which doesn't seem to be the case here. The VHF counties are far from the Travis County area, in some cases I'd estimate a couple of hundred miles away. As such, I'd have to figure that they are using the controller core, but are otherwise independently operated.
The obvious answer is that a mixture of implicit and explicit sites are in operation. I'd guess that systems like this are fairly rare, so maybe it's not a good example to use to explain implicit versus explicit.
Note that a system can use a combination of implicit and explicit signaling. The PA-STARNet system, for example, uses implicit signaling for the UHF, 700, and 800 MHz sites within the system, whereas the majority of VHF sites are using explicit signaling. There are some VHF entries in the band plan, however that does not cover all of the possible channels used on the system, and thus explicit signaling must also be used.
I'm sorry, is our discussion bothering you? No one forced you to participate in this thread, last I checked.So the question is why are you and others beating this to death? It seems to be pretty straightforward.
I'm not beating anything to death, I'm simply pointing out that Uniden America's new Product Manager has at least twice posted something inaccurate when it comes to implicit/explicit P25 signaling. Sorry, but someone in that position should probably get a handle on the concept before making inaccurate posts.
I tried to explain this to him a month ago in this thread: SDS200 Squelch. 1= Static , 2= Not sensitive enough
Those models were apparently unable to decode the over-the-air band plan for implicit systems or the multi-block messaging for explicit systems.
I very much doubt it was a P25 system if it didn't transmit IDEN_UP messages, aka a Channel ID plan, aka a Band Plan, aka the 16 channel table.You described two systems for implicit and explicit - neither of which are the system type I'm talking about that was said to be implicit by the system manager because it did not transmit bandplans, but only table assignments.
I know you're familiar with that system, which is why I used it as an example. You are being fooled into believing that this 16 channel band plan covers every VHF possibility, which it most certain does not.I happen to be familiar with this system, and I have never seen any frequency assignment that is not using a bandplan assignment. Virtually every frequency is covered. The first four entries are always 800/700 MHz. The remainder are for the band used by the site.
As you can see, the bandplan covers every 800, 700, and VHF frequency in Phase I or Phase II in 2.5 kHz steps. UHF excludes some of the T-band but covers every frequency 450-481(and change)MHz at 6.25 kHz steps. So every frequency used is in the table allocation. BTW, CH# = max except for one entry I forgot to max out. So freq calc is the max frequency for that entry except for table 4 (which covers to 174.9975 MHz). VHF would use tables 8 and 11 for the most part to cover 150-174 MHz. Checking a few sites, they are using 8, 10, and 11 on VHF.
So Starnet seems to be a regular P25 system just like nearly any other Motorola Phase II system. It definitely uses tables for the assignments.
Band plan = "16 table entry". You are literally describing the same thing using different terms. Any site in a system that relies solely on the band plan/16 table entry/Channel ID plan/etc. is using implicit signaling, period. If the channel assignments are not able to be covered by the 16 entries in the table/band plan, then the system must use explicit signaling to some degree.That's funny after I said very early on that I might be wrong, but there has yet to be an answer given on the type of system I have always known as implicit that uses no bandplans and assigns voice channels based on one of the 16 table entries.
If you want to take this discussion off the forum so we can go into more detail, feel free to PM me and we'll either chat there or via email. This is probably getting a bit tedious for most users on the forum.
In fact, let's review it: (if this will post correctly)
