Control Channel
funcritter
Denver
Sometimes my Pro-96 will stop on a control channel and will not scan as its stuck on that channel. What do I need to do when this happens? It's happened about three times in the months since I have had it.
Thanks!
W4KRR
Coconut Creek, FL
Thanks!
The scanner should not be stopping on the control channel ever. If it does, you probably have the scanner programmed incorrectly. Make sure all the frequencies are set to the proper mode, that is "MO" if it's a Motorola system, or "ED" if it's an EDACS system. Also make sure the bank's mode is set accordingly.
davidd2957
Suffolk County N.Y.
Thanks!
funcritter...what system (state,city, etc.) are you monitoring?
David D.
funcritter
Denver
David D.
This is in Colorado, the Westminster PD. They are on Edacs. I haven't had this happen on my Pro 97, only on the 96.
