Mikeg5513
Where I work at, we use an 800mhz Edacs trunk system. I used to have the correct control channels programmed into my pro-95 and everything was fine until.....
...About a month ago my company switched to new frequencies. I brought my frequency counter to work the other day, and keyed up the MIC on my base station several times. I obtained 9 different frequencies. If I remember correctly there should be 10??
Here is my question. Those 9 frequencies should be the ones I program into my scanner correct?
I looked on the database here on RR and its not updated to the new system, only the old list of control channels are listed.
Any help would be greatly appreciated.
Mike
Mike
