This is a minor extension to some other threads of late about trouble getting units to scan but mostly for my own understanding.
I personally run Control Channel Only because as I understand it when the unit scans that "system" as it is programmed in even if you input all the frequencies from a particular tower it will stop scanning as soon as it gets to the control channel, unless there is someone on the voice channels. But sooner or later it will get to the CC and stop scanning and lock on to the data coming from that site. It takes that data and reads it and then tunes to the voice channel active for a particular TG. I have had no problems pre-rebanding or post rebanding using my little BC246. I use it everyday and drive from Tooele to Utah County work days and take it with me so I get signals off several sites it’s always seamless.
So what I do not understand is what it the need or benefit of programming in all of the frequencies from the sites for the system you are creating? I know there are older model units that needed all the frequencies but all these new units support CC only.
Thoughts? Comments? Insight?
