Control Channels
everonward
Do you have to put in all the Control Channels in a Trunk system or can you use just the Primary Control Channels.
nd5y
Wichita Falls, TX
You only need the current active control channel, but if it changes to a frequency that you don't have programmed then your scanner will no longer track the system and you will wonder why you are no longer hearing anything.
GTR8000
NY/NJ Database Guy
BEE00
You really ought to program all identified CC's, they can change at any time. Yes, some systems, P25 in particular, are very stable and the CC may never roll...but it doesn't hurt to have them programmed just in case they do.
