"control lock" mode or similar for XTS2500
aw113sgte
What I'm looking for is a way to lock the keypad, channel, zone, etc. volume at a specified level would be great too. Basically for fire interior operations where bumping controls can and does happen. I did find some emergency features but they don't really seem to be appropriate as they are more for sending tones. There is a "soft power down" which requires a button press to shut the radio down so that could help a little. Any ideas?
We are on analog VHF.
K2NEC
The closest thing possible is keypad lock but that won't lock your channel or volume
chrismol1
P25 TruCking!
Rotary Switch Lock Enable
(Radio Wide, Advanced)
Enables the radio's currently selected channel to be locked in place even when the rotary switch position is moved. This feature can be toggled on and off with a radio-user initiated "Keypad Lock" button press or switch toggle. This feature applies on a radio wide basis.
The radio-user "Keypad Lock" button press or switch toggle must also be CPS-defined.
and with a capable speaker mic lockout the radio knob
RSM Locks Radio Channel / Volume
(Radio Wide, Advanced II)
Enables the RSM (Remote Speaker Microphone) volume and channel controls to override and lock out the radio’s volume and channel controls. This feature applies on a radio wide basis. This field should NOT be enabled if the RMN5067 microphone is in use, since this mic has no channel control knob.
aw113sgte
We aren't running RSMs with channel/volume so I can't use that option.
I see the rotary switch lock but it's all grayed out, wonder if I need a firmware update.
