Control Vs Licensed
Check the manual to see if it supports control channel only. If it does then you can program in the control channel only. However, if the control channel chnages it will not be detected except for no traffic on your scanner.
fineshot1
NJ USA (Republic of NJ)
Skud - you would also need to program in the alternate control channels(868.5125, 868.7625)
as well. If the primary is down for any reason control shifts to one of the alternates.
