Conventional frequencies or P25?
mocman
LaGrange Ga 30241
When I program my local Troup county agencies into my scanner. Is it necessary to program it with conventional codes along side P25? I have RS 106 pro and whistler 1040 scanners. Just do not want any sort of conflict if any whatsoever.
mocman
LaGrange Ga 30241
Well I program my scanners I have always programmed them with P25 and Conventional.....Just need to know if I need to just do P25 only.....Thanks
You would be the one to answer that, if you are hearing traffic on the conventional frequencies go ahead and program them separately from the trunked system, if you aren't then just program in the trunked P25 system and talkgroups.
