Conventional provoice programming question...
emtLarmy15
Pocomoke City, MD
Matt,
An interesting note on your gripe about the priorities. On a regular scan list (no P1 select) I had mine set up with 14 pri 3's, 1 pri 2, and 1 pri 1...But I the talkgroup I was selected to talkon was actually my priority 1, even without P1 select.
Hope that made sense
Chris
INDY72
Indianapolis, IN
Ummmm I didn't think they had Provoice capable conventional yet.
Anyone care to point me to a conventional system in the US that uses PV for digital????
emtLarmy15
Pocomoke City, MD
I know for 100% FACT that it Pro-Voice is available for conventional talkaround... My police Jaguar 700p scan model radio has analog/pro-voice talkgroups as well as analog/pro-voice conventional freqs. My county has (in addition to the NSPAC freq's) 6 conventional freqs programmed into every radio in the county. The freqs are named direct 1-6... on the police radios we have dirdig which is direct 5 in pro-voice mode... real fun to mess with firemen and tell them to go to direct 5 and I talk in pro-voice and they obviously only hear the digital noise.... gets me a good laugh every time.
Chris
INDY72
Indianapolis, IN
Now thats just wrong on too many levels....LOL
The 800 MHz conventional freqs were never meant as a game playing system.... Those were set aside for conventional interop.... Anyway.. I still ask: What Conventional System uses Provoice Digital Modulation?
Show me a single conventional system in the USA that does so as its standard format.
Playing with your radio and a friend's is one thing.. SOP for a system is another.
RF-Intel
The attached PDF should help you out...
MatteBlack said:
I am trying to program my Jaguar 700p for conventional in provoice mode and am not having any luck. The radio is definitely provoice capable, as I am able to monitor provoice groups no problem, and have been for a long time. Now that I want to try a conventional provoice set I am running into roadblocks. What am I missing? The channel will show an activity indicator, but the squelch will not break.
blantonl
Founder and CEO
Staff member
Super Moderator
Dallas, TX
chrisjz said:
You can program the LCN's of a ProVoice EDACS system and flag them as ProVoice enabled in conventional but when the channel is assigned you will hear nothing. This is because the header information of EDACS ProVoice is different from conventional ProVoice. In conventional the header contains a series of 69696969 (not sure how many) to indicate a digital signal and the receiver should unsquelch and listen. However, when trunking the EDACS signaling is used as the header and that is where the difference is, this is why the receiver will never open on an EDACS ProVoice call while listening to it conventionally, even with your radio programmed for ProVoice properly.
This is not correct. The data is simply inverted, and the RX Net ID needs to be set to the all call Net ID as defined in the documentation. Therefore, conventional personalities can be programmed to monitor ProVoice LCNs.
RF-Intel
Quite right Lindsay, it works well.
Set "Digital Voice Options" to RX and TX Inverted
Set all LCN frequencies to "RX Address" 172
Now, theoretically, you can set an RX CG/DCG on each channel and scan hearing only the PV, skipping any disconnect tones. However, it seems that even with "Scan with CG" set that any carrier will open the squelch and stop scan... Any ideas on this?
mryvr
Nice find guys. I'll try it out and post with any findings.
mrYvr
