Is anyone been able to convert an RTSP feed from a BCD536HP to a UDP feed using FFMPEG?
I've tried to listen to the feed with FFPLAY with no succes. I alway end up with a "server bad request - error 400".
The feed is playable fine in VLC.
Here is a screenshot of the VLC RTSP connection sequence.
And the catpure of the same connection using FFPLAY (FFMPEG)
As you can see, I'm forcing a TCP connection (FFPLAY use RTSP over UDP by default).
I have developped the content of the SETUP packet because the bad request status come right after this command.
I'va tried lot of flags / parameter with ffplay... always the same result.
Anyone has a magioc formula to listen to this feed?
