convert text files to csv format
Is there an easy or simple way to convert .txt files to csv for import using Don Starr's win 97 program
Paul
P.S. I did Google but am more confused now than I was :)
newbie
St Clair, Michigan
Paul
Open in word or some other program
Search & Replace for whatever seperates the columns ( tabs, several spaces....)
OkRob
You can import a .txt file into Excel or several other programs and make a .csv file from there easily. If you don't have Excel, look into OpenOffice or one of several other freebies.
- Rob
hmm thanks I sem to recall thatnow about excel , would an excel file viwer do the same thing, Will look for 1 and try it\
thanks
fmon
Silent Key Jan. 14, 2012
Eclipse, Virginia
!st thing to do is export a Win97 file to csv. The file which you structured needs to be set the same or it won't import. However, blank frequency locations and blank trunking TG locations can be ignored in the setup.
I dled Excel viwer & bah! didnt work, no where to import a file.. . again whgat I want to do is take a plain text file that I have made & convert to csv format so I can import it using win97. Thank for all the replies so far
PAul
seamusg
Grand Blanc, MI
PAul
Their is no majic way to do it. What you have to do is:
1. Know the format Win97 wants.
2 Write a program to convert the text file to the format what Win 97 wants.
csv is not a everything format it is a file type - comma seperated values but it does not say what each value must be - only the App reading the file defines this- A csv file could be Name ,Address , Phone etc. It's not unique to scanners - it's the most common and oldest way to store data. Fields in a csv file are defined by the App (ie. Win97) their used with.
