Convert TK-5230 to NX-5200?
Disp46
I have a TK-5230 radio that I would like to add DMR to. I purchased and added the DMR CV feature license in LCM but with the 5230, it is a P25 only radio, no NXDN or DMR is recognized. Is it possible to flash NX5200 firmware into this radio so that I can write the DMR features in KPG-D1N using an NX5200 profile? If I try that currently I get a model mismatch error (because the radio is telling KPG-D1N that it is actually a TK-5230). Any help would be appreciated.
That radio will not do DMR.
You can't force NX-5x00 firmware into it, completely different radio, different RF section, different controller.
And KPG-D1N is never going to talk to that radio.
If you want DMR, you need to look at the NX-1000, NX-3000 or NX-5000 line of radios.
Disp46
You might be thinking of the TK-5320 (transposed numbers) because KPG-D1N is the software I have to use to program it currently. It is a TK-5230 in fact there are two labels on the chassis, one that says TK-5230 and the other says NX-5230 on the main Kenwood label.
That's an EF Johnson variation of the NX-5x00. The transition between Kenwood/EF Johnson has been a bit messy at times.
EF Johnson will not support NXDN or DMR.
I don't know if you could cram Kenwood NX-5000 firmware in there or not, I don't have one to try it on, and I'd be reluctant to do that.
Are you located in the USA, or Canada?
Disp46
I’m just wondering if anyone has actually tried and succeeded with loading NX5200 firmware into a TK-5230. My instincts are that it might just work. The firmware version numbers match identically. In fact the newest version I just installed today was titled NX-5400K2.
I've done things with firmware where I switched ProTalk radios to 'regular' radios and it's been successful.
I have not attempted forcing Kenwood NX-5x00 firmware into an EF Johnson radio. I agree, it would probably work, but the having to send it in for repair might be costly.
Thing that would concern me is if KPT-300 would recognize it or not. I'd want the Kenwood firmware and the EF Johnson firmware so I could switch it back.
I'd love to hear if someone has done it, too.
N5XPM
Texas
Trying the Kenwood NX firmware on the EFJ TK series is a bold adventure.
If it initially worked, I would be concerned that any purchased upgrades down the road might not work with the next version of Kenwood firmware and you would lose the purchased upgrades.
Might be a little more to sell the TK and purchase the NX and add the desired DMR upgrade (which is pretty reasonable), but might result in a better long-term outcome. The radio would then do analog, DMR and NXDN.
cyberock
Can't do it.
Disp46
You can convert your TX-5230 by TRADING it and CASH with your local Kenwood Dealer for a NX-5200
You’re right. They’ll be going up for sale. I already have P25 only APX’s which serve me well. I just desired the dual functionality of P25 and DMR in one radio.
kd4efm
EL98 Florida
I have an email into Long Beach to find out some more information on this.
I feel like it's a locked down P25 only radio for it's reasons.
Disp46
I appreciate you looking into this for me and am curious to see what those reasons are.
kd4efm
EL98 Florida
From Kenwood,
Evans,
The firmware and KPG-D1 software for the TK-5x30 and NX-5000 Series radios are common. Because they are common changing the firmware will not change the model.
It is my understanding that the model name and features associated with the basic model cannot be converted to a different model.
Below are the features of the TK-5x30 Series. DMR is not included and cannot be added as an option.
87622
Please contact EF Johnson if you have further questions on converting or adding features to the TK-5x30 Series.
Thank you,
Disp46
From Kenwood,
Evans,
Thank you,
A sincere thank you for taking the time to make the inquiry on this and for providing the official response from JVCK/EFJ on this. It really is appreciated!
celltech25
Benton
The 5x30 series was launched to pacify some state grant people that required the radio to only do Analog and P25. They would deny any grant that asked for the NX5000 series and require the older 5220 or the newer 5230 or there UHF equivalent.
And I know that's dumb as can be I guess they don't want true interop
k4ktr
Elizbethtown,kentucky
This is a Kentucky Problem the grant guy here is a motorola trihard for some reason
