Converting an XTL5000 W5 to O5
jaolson101
Wendell, NC
I understand that Moto sells a conversion kit to change a W5 trunkmount into an O5 trunkmount. Does anyone have any experience with this? How detailed is the conversion? What are the advantages of doing same?
Thanks,
n3obl
Ø
PA
Im going to talk about the dash first before I go into a remote mount.
Converting a dash mount requires the following. A o5 head, headbridge (plastic spacer from body to head), new flex cable.
With regard to a remote mount, you have additional pieces. the TIB (radio body piece), CHIB (control head back) and different remote cable going from a W series to an O series.
Most of my dept radios are O series with the exception of two older ambulances as they have the w series remote in them with dual head and probably would be cost prohibited to change out at this time. When the radio get pulled to go to a new unit will be when I make the switch over.
Frank
henryvb3
Montgomery, IL
I'm looking to make my dash mount w5 an O5. I see the parts you listed below. Do you happen to have part numbers? Any firmware change? I see an option in CPS to change control heads but don't know if that's all that needs to happen? I have an O5 head but need the cable and spacer.
Thanks!
Henry
