Pro-95
I've been doing a bit of reading on antennas. I found many references to the "Copper Cactus" or J-pole styled antenna. Seems as though this a popular and arguably easy to do, for the do it your-selfer antenna builder.
This antenna also seems to be able to produce some, albeit nominal, gain and if designd and cut for 144, 440, 900 Mhz could be a decent antenna. I found reference for even a 4 band J-pole.
I've also talked with a couple of people regarding antenna farms and they all seem to indicate that since there is no transmitting taking place that simply "T"ing connections should'nt have much effect of the listerners signals.
So has anyone built a copper cactus? Did you have much success with it? What about the "T" comment over duplex/diplex/multiplxing the signals to combine into one line down to a scanner?
