oneirish
- Joined
- Jul 9, 2008
- Messages
- 33
- Reaction score
- 0
I've been running a 65' bare copper wire connected to a WiNRADiO WR-LWA-0130 Long Wire Adapter
( http://www.winradio.com/home/lwa.htm ) and then to coax coming inside for about a year. Originally intended as a temporary HF solution but it worked so well I left it up.
Now of course the wire is brown with oxidation (?) and the many air pollutants here in LA. Yet I still pick up most stations I did before with the exception of hearing east coast like HF-GCS very often from KADW.
I took it down to clean the balun up and have another 65' of bare copper but should I go buy jacketed wire instead before putting it back up?
How much does the weathering of the bare wire affect performance over time?
I also have a PAR EndFedZ up and they both perform about the same except the 65' wire is slightly better on weaker signals and around 10 MHz.
