That's not going to help you one bit. The scanner doesn't need all that stuff to track it. Its a P25 standard system, and any scanner that can do P25 control channel only trunking on 800 MHz from the factory doesn't need all the extra specs you are asking for.
If you want to listen to the input channels, they use the standard 800 MHz repeater shift of -45MHz below the output channels. Of course you'll have to listen to those in conventional mode, and you're only going to hear mobiles transmitting when they're very close, and you're not going to hear Control at all, because they're all on wireline consoles.
You mean you don't have any outdoor 800 MHz antennas in **The Northwest Communications Center**? All you need is a little 800 MHz Yagi fed with some decent coax pointed at the nearest MECA transmit site. In most cases, this will solve your issues. Dedicate one of your multitude of scanners only to MECA, point the antenna directly at the site, and don't mess with it. Until you are willing to do that, quit whining about how your $400 scanner chokes on LSM CQPSK P25. People on here have presented you with the solutions dozens of times, but for some reason you think you should be able to listen to the system using a paperclip in your mom's basement. Welcome to Digital Trunking.
