Could someone explain this antenna spec to me
70cutlass442
I am looking at a UHF antenna for my Humvee. They are not easy to find. I can get one that is used primarily for positioning and locating and they list this in the specs:
10 Watt CW, 200 Watt Peak, 2% Duty Cycle, 1 Millisecond on time
Seems low but I have no issue running 10 watts or less for GMRS or Ham. My concern is it saws 10 watts on CW. Is CW different than voice when we are talking RF power output?
RFI-EMI-GUY
That antenna spec sounds like some avionics or military spec. It sounds totally unsuitable for GMRS. What is the model number? Why not one of the many affordable Larsen NMO mount antennas?
prcguy
Is the antenna a 4 bolt pattern for the scoop mount over a tail light? I may have some Shakespeare UHF mil 4 bolt antennas in my garage that would cover GMRS with a 70 watt rating. I will dig around tomorrow to find them. I believe the are this model. 4266 UHF Antenna - Shakespeare Military Antennas
What you really want is the 30-512MHz version with diplexer so you can run a CB and GMRS at the same time. I have a couple of these also. SFB3512D/VRC Multi-Band Antenna With Diplexer - Shakespeare Military Antennas
70cutlass442
I will take the 4266 if you have one. That is exactly what I am looking for actually. I was going to settle for this since it was cheap.
70cutlass442
Us military vehicle guys are somewhat purists when it comes to certain things. I could easily make a plate and screw a NMO mount to it utilizing the existing mount, but that distracts from the original look which I want to avoid.
prcguy
I found the antennas and one is a Shakespeare 4310 that covers 225 to 420MHz and the other is a RAMI that covers 420 to 450Mhz, neither are good for GMRS. I also found a couple of VHF 118 to 174MHz and the 30-512 versions, which I don't want to part with but they are out there surplus.
Crap.
RFI-EMI-GUY
I am sure somewhere out in the wild is a military Humvee with an NMO mount bodged on. There may even be an adapter.
The 1 ms on time is new to me, sounds like an active component. Never seen duty cycle listed but I don't look at antenna specs often, is that something new? If my math is correct transmitting for 5 seconds in a minute is 8% duty cycle.
RFI-EMI-GUY
Those specs sound like what would be used for a radar or radar transponder. Those applications use a very high peak power and low average power. Your concern would be CW, or continuous wave (average) power.
5/60=8.33%
