I didn't say that. I said: Even if it's used for other things, it was still an out of pocket expense that is necessary to make the dongles work. If you have a source for free PC's, please share it.
This thread is about "solving" the LSM problem. Max has created a solution that uses $20 dongles. The *point* is that this solution uses a $20 dongle to provide
all of the RF hardware. I doesn't take expensive hardware to handle LSM.
Saying "Oh, but you need a $400 PC to make it work." is a classic strawman. Max doesn't claim that $20 provides everything required. He claims (quite correctly) that fancy hardware is not required. Every solution has more hardware beyond the RF section - a scanner has a microprocessor, memory, keypad, display, power circuits and a dongle has a PC, a PC that most of us already have, so when he talks about it being a $20 solution, for most of us, it is. He doesn't claim it's a "$20 all in" solution, so where are the $20 Uniden LSM-capable digital scanners...
In an attempt to weaken Max's simple message, Voyager throws in the claim that dongles = high data rates = high end processor required. Sure, the dongles are designed for high data rates (about 6 Msps) because they have to handle wide digital TV signals. But they are also quite capable of sampling small chunks of spectrum, say, 100 kHz or less, for example and presenting only that spectrum to a processor. Now we're down to 100 ksps or less, not the 2+ Msps that Voyager would have you believe a processor will have to deal with. Now we're getting down to data rates that scanners already deal with. Any scanner-based LSM solution would have inexpensive dedicated hardware dealing with tuning, filtering, downsampling, etc. before passing the torch to a general purpose microprocessor - just like they do now. So much for that bit of FUD.
And Max has already covered the fact that existing scanners already have the necessary licensing in place. There are no patent holders to pay for the privilege of processing amplitude modulated phase shifted signals.
