KA1RBI
Actually, the thread is titled: "Could Uniden Ever Design A Scanner To Properly Decode Trunked Simulcast Systems?"
Unless Max works for Uniden and is actively introducing his solution to their products, it is off topic.
No, I don't work for Uniden. I actually couldn't care less what they do. If they offered me that job, I'd very likely refuse.
In order to properly answer the OP question it's necessary to do an analysis of what the problem is at the appropriate technical level of detail. UNIDEN NEEDS TO IMPLEMENT A DIFFERENTIAL QPSK DEMODULATOR. CQPSK MUST BE DEMODULATED ***AS QPSK***, NOT AS C4FM.
Anyone can claim they have the One True Revelation of the Real Reason why scanners suck at LSM.
For example, someone could claim that adding a dab of Cream Cheese to your antenna connector will fix all your LSM troubles.
However, in my view anyone claiming to have a fix for LSM had better have documentation to support that claim, including testimonials from actual users who have tried it.
Why are you singling out that documentation as off-topic, while leaving alone all of the FUD heretofore posted? Is that on-topic?
73
Max
p.s. Here's a snip from a PM I received the other day...
I really appreciate your words of wisdom on Radio Refence forums about why scanners do a terrible job with CQPSK. You state the truth and explain it clearly. I am a retired telecom engineer and have been involved with2-way service since 1962. The bottom line is you can't run a signal with AM components through a limiter/discriminator without distorting the data...
Here's another snip
I gave up on any posting on Radio Reference 2 years ago when I could no longer stand the mis-information from the self appointed "experts" on there.
