BCD396XT: Counterpoise on BCD396XT
Decided to try this on the hand held scanner and it improved my rx. We have a small p25 police department that is about 5+ mi from me and I can't pick them up unless I am using a large antenna, (something other than portable any duck antenna). Stuck the counterpouse which is about 19" ± and screwed the stock antenna and lone n behold receive is 99% better. Just thought I would share this.
NWI_Scanner_Guy
SCANNING THE AIRWAVES SINCE 1987
Hammond, IN
I saw this explained recently on a YouTube video but in conjunction with ham radio handhelds. Decided to try it with my kg-uv8d and it improved both tx and rx. Going to have to give it a try with a couple of scanners and see how it fares.
How did it work out ?
Sent from my SCH-I605
ka3jjz
Wiki Admin Emeritus
Bowie, Md.
Yes that's correct.
A company some years back called this a 'Tigers Tail'. Probably made a bunch of money from folks who didn't know you could do the exact same thing for much less than they were charging...Mike
frazpo
SW Mo
yep
Yes that's correct.
I had the stuff laying around. Ive made two this evening already. I had no doubt it would improve reception but I was shocked at just how well. I carry a 396 everywhere and any little bit of improvement to the standard rubber ducky is welcome.
jonwienke
More Info Coming Soon!
VA
Another thought is to use the headphone cord to form a J-pole antenna. If you have the scanner on your hip and you have the headphone cord go straight up from the scanner, the ducky becomes the short segment of the J-pole and the headphone cord becomes the long segment. It works surprisingly well for VHF frequencies.
I always strip back an inch or two make a loop solder and smash it flat like a washer just large enough for the SMA connection. I have rattails for 6m 2m 70cm and 800mhz. They are not interchangeable based off my tests a 6m tail will not work on 800mhz. As for the scanner and the tail I use something I made with calculations between 2m and 70cm like 18"±
