Couple KVL Questions
BinaryMode
75 parsecs away
Can a KVL generate a random key or is it made up by the person inputing the key? If the KVL can generate a random key, what is its source of randomness?
Thanks.
K2NEC
NA
Yes it can generate a random key. As to how, I'm sure it has an algorithm internally that does such
MatRat80109
Colorado
Keys are created/added in the Manage Keys menu section. You have the ability to enter your own key data or select Auto for a random key to be generated. Write it down, this is the only chance you'll get to see the actual key data. The randomness and algorithm used will be closely guarded secrets, particularly since these are used by government agencies.
MR
