Tytera Couple questions on the TYT TH-8600
KD8EMC
Hello,
I recently came into possession of a TYT-8600. I've looked through the manual and searched online and there are 2 questions that I can't seem to find an answer for.
1) How can/can you reset this radio back to factory?
2) Once you have a channel programmed into memory and then you manually update it (like change the offset direction on a repeater), how can you save those settings back to that memory channel - basically overwrite that memory slot with the new settings?
Thanks in advance for the help!
OffroadMedic
Hi, did you ever find a solution resetting the radio? My menu buttons on either the radio or hand set are not working.
AI6VX
Ventura, CA
FWIW, I can't figure it out either. I programmed mine using the software but have one of the PL tones wrong. I can update it on the radio by hand, I can go through the motions of saving it to the same memory location, but when I change channels and go back, the old settings are there.
Tonight I'll just drag the laptop out to my car, but I'd still like to know how to do it from the radio itself.
KD8EMC
I was able to find how to reset..... Menu->Utilities->Radio Settings->Reset (menu option 28, I believe).
krokus
Southeastern Michigan
Have you tried calling up the programmed info, send that to VFO mode, then save that back to the memory location?
nd5y
Wichita Falls, TX
It's probably just like some other CCRs.You can't directly edit memory channels. You have to delete the memory channel and start over.
KD8EMC
If I recall correctly, manually updating/saving to the memory channel never seemed to save, however, overwriting the memory/config with the software did update things properly.
AI6VX
Ventura, CA
Thanks all. I just used the software to update it. There was no manual way to do it from the radio itself on top of the existing channel. Krokus, I didn't know I could transfer the memory channel to the VFO. I'll look into that for future reference.
