Hello,
I recently came into possession of a TYT-8600. I've looked through the manual and searched online and there are 2 questions that I can't seem to find an answer for.
1) How can/can you reset this radio back to factory?
2) Once you have a channel programmed into memory and then you manually update it (like change the offset direction on a repeater), how can you save those settings back to that memory channel - basically overwrite that memory slot with the new settings?
Thanks in advance for the help!
