Couple ?'s on the G4/5
mmartinfan
Banned
In a house in Ohio
I would mainly use it for Ohio MARCS in Columbus Ohio.
Am I able to scan the MARCS system at the same time I scan the City of Columbus system (Its backbone is MARCS but a separate site.)
Also same question as before but instead of the city site, scan I use it scan the Franklin County sites also?
Also I dont think I can scan across to a different system (i.e COIRS which has Dublin, Hilliard, Worthington and Delaware,)
I think I'm limited on TG's I can enter per site correct.
pike63
Sorry I.m just getting started with the G5 but you can only scan one system at a time. And you can not scan a trunked system on the 7/800 mHz side and a VHF channel at the same time You can setup different systems and scan them by assigning them to different zones and or positions on the selector switch
David_Oney
Former Unication Tech Support
Raceland, KY
As long as they share the same WACN and System ID you should be good. Im pretty sure Columbus city is on MARCS so it should work.
mkinkade
Central Ohio
It sounds like you're saying it can monitor more than one control channel at the same time, which is what he was asking. (The state, county, and city are all on separate sites). How do you do that?
David_Oney
Raceland, KY
I must have misunderstood I thought the question was if he could have them on the same knob position. The unit can only lock on to 1 site at a time.
