sparklehorse
This will be sort of two posts in one. I’m posting in the Oregon Forum because I assume most scanner folk in the Vancouver area check this forum. I’ll have the thread moved to the Washington Forum after a time.
So first off, today I’ve been hearing Cowlitz County Sheriff Dispatch (154.815) crosspatched to the CRESA 911 p25 system on talkgroup 15200. I’ve been monitoring CRESA in ID Search mode for a couple months but this is the first I’ve heard this talkgroup. It’s been active for well over an hour now. Unknown if it will remain active indefinitely. The audio isn’t great as is often the case with analog crosspatches on p25. I have submitted the info for a database update.
The other thing of note is that a couple weeks ago I tried programming WSP Vancouver into my SDS200 as a One Frequency trunk system and it really improved my reception. WSP has been problematic for me ever since they switched to p25 conventional several years back. It’s always been intermittently choppy with occasional dropped or clipped transmissions. I had chalked it up to likely being due to simulcast distortion, even though it’s never been clear to me whether their signal is even actually simulcast. The crosspatch for WSP on JIWN hasn’t been exactly stellar either, even on the SDS. Same with the crosspatch on CRESA 911 p25. But for some reason as a One Frequency trunk on the SDS it sounds really good. I got the idea after seeing UPMan suggest this to solve a similar problem on p25 conventional a while back. I’ve also tried this on my BCD436HP and it’s working pretty well there too. Might be worth a shot if you’ve also been having problems with the WSP signal.
