Cp200 as pager
I have a cp200 that im trying to set up a page only channel so that the channel only becomes active when the correct tones are transmitted. I have programmed everything thing into the quickcall II screen and set up the personality but I still cant get the channel to only unmute when the tones are dropped, the channel is always receiving. What am i doing wrong?
SteveC0625
Order of the Golden Dino since 1972
Northville, NY (Fulton County)
In your paging personality, change Signaling Squelch to be "And".
Do not set this up to scan.
Also, be sure to have one of your programmable buttons set to be Monitor. That is your reset button.
Okay perfect, switched that and it works like a charm.
Now maybe you can help me with my XTS1500. I am trying to do the same thing with that radio but am running into an issue. The radio is a non display 15000.. when I go into CPS to set the quickcall up the entire area is grayed out. I have tried everything and it still stays grayed. Is it possible that this feature inst available on this radio?
SteveC0625
It's possible, but that product line is not in my area of interest so I can't really help you with it.
