CP200d help
K2NEC
Hi all,
I have a CP200d that is the analog version and recently thought about getting the digital upgrade for it. There is just one problem. After the upgrade you are supposed to upgrade the firmware and the radio already has 1.1.30 so there is nothing to upgrade to. As far as I know there is nothing newer than 1.1.30 right? So theoretically, until Moto comes out with a new firmware for the radio I am stuck with analog only right?
K2NEC
I thought you had to update the firmware after you upgrade the feature?
I read on the forum that a member upgraded the firmware before the feature and was stuck with an analog CP200d. I guess that's not the case?
ChrisE_STB
CA Database Admin
Bay Area
That is not the case, add the digital entitlement and you will be fine. No Firmware bump is needed when adding entitlements.
K2NEC
Got it. So pretty much you just have to update the firmware because R1.1.01 doesn't support digital. Thanks guys
Project25_MASTR
Millennial Graying OBT Guy
Texas
CP200d's sold as analog only have an analog only firmware on them. The firmware has to be upgraded if you purchase the EID for digital to unlock digital function.
KG4INW
Midlothian, VA
Right, register then activate the EID, followed by updating the firmware, even if that means the exact same package the radio is already on. I've changed several hundred CP200ds from analog to digital with very few issues.
Project25_MASTR
Texas
Same process on the CM200d and CM300d.
KG4INW
Midlothian, VA
Precisely. Also, any saved analog only codeplugs are no longer compatible with your digital radio now.
Clementwu1517
San Francisco
Hello I need a little help I have been tearing out my hair for the past couple days I have this CP200D that I got the digital entitlement, Activated it and now it wont let me write to the radio its asking me to upgrade the radio firmware.. I have no idea where to get this file at. When I try and update it says I do not have the package.
Info: CPS V16 build 823
This is what it shows under details
Firmware: Analog (Even though I see DMR on the left hand selection)
version: R01.01.01
codeplug: 07.07.08
boot: R02.40.00
Is there anyone that can provide me a file or direction of where in the world to get the update?
Thank you
Floridarailfanning
East Tennessee
version: R01.01.01
codeplug: 07.07.08
boot: R02.40.00
Thank you
In MOL go to the Resource Center then Software >Two-Way > MOTOTRBO > Conventional - Firmware and there will be an option for MOTOTRBO Digital Firmware for SL, CP, and CM radios. You'll need to install the portable light package.
Clementwu1517
San Francisco
I had a feeling it was under MOL... sadly I don’t have an account on there and last time I tried to sign up for MOL they never got back to me ://
