CP200D Pre ID MDC issue
zacsharpe
Hamlet, NC
Hello all, I have got a CP200d Mototrbo radio. I tried to program a personality with a Pre-MDC personality but the radio won't transmit the ID. Seems like the radio isn't transmitting in time or something. Not quite sure. Any help is greatly appreciated!
Thanks in advance, Zac
vans113
Tennessee
You setup the MDC , but did you assign it the MDC to transmit with the channel you're trying to talk on?
N1GTL
CT
Not really much to it. in MDC, set the PTT to pre, which it sounds like you did. The only thing I can think of is you need to set the signaling system in the channel, make sure you set it on the TX side. There are drop downs for TX and RX.
TampaTyron
Tampa, FL
How do you know it is not transmitting it? Are you listening in CSQ to the channel? Is there no MDC wait beep? Is it not showing up on other radios? TT
zacsharpe
Hamlet, NC
I'm transmitting on a PL. The other radios get the ID but it's not audible. Yes, I am aware of the DOS on the receiving radios. I have one with DOS and one beside it without DOS and neither will hear the data burst and put it through the speaker.
KG4INW
Midlothian, VA
So, it's working then? It's OK if you don't hear anything as long as the other radios are reliably decoding it, unless if I'm missing something with your last post.
62Truck
Uranus
What model radios are receiving on?
N1GTL
CT
Are you going through a repeater? It may be sending the MDC but, depending on receivers, voters and such, the pre time might not be set high enough. I think the default is 500ms. Bump it to 700ms?
parma,ohio
MDC ID
Question do you have 2 radios with the same ID is this what your doing? if both have the same IDs it will NOT show that ID being both radios have the same ID.This happen to me a long time ago
