tropiradio
- Joined
- Mar 10, 2021
- Messages
- 237
- Reaction score
- 24
Got this CP200d VHF which was working perfectly for months and now seems to be completely dead as there is absolutely no activity or indication other than it lights up the front green LED upon power up, but the LED stays on continuously after that, no boot confirmation tones at all, none of the side buttons operate, or even any alert tone when radio is set to an unprogrammed channel. The radio will not even power down with the power switch. I actually have to remove the battery for the green LED to turn off.
I tried to read the radio with CPS 16 (it was programmed this way some time ago) without any luck as it is not even seen by CPS, and sure enough in Device Manager cannot even see a network port being opened as it usually happens when a functioning radio is connected. The programming cable works perfectly with other radios, so that is not suspect. The radio was not dropped or was even in the charger when this problem happened. According to the user, one evening it was working, the next morning out of the blue the issue started.
Anyone have an idea of how to possibly solve this problem? Thanks in advance for any suggestions.
