CPS for HP785G BT Uv
AndySS
Hello everybody.
I need CPS for programming HP785G BT Uv.
Official site have only DMR_SW_CPS_V9.02.13.001.iM(chs). This software don't work and gives CPS error message.
dazey77
That is not the right software at all. What you want the new HP series CPS 2.0.01.004/6/9 (later required for later firmwares). You also need EM5. You should really ask your supplier to provide you with the CPS.
See your PMs
AndySS
Thanks!
Hmm.. CPS 2.0.01.004 for HYTERA.
I am try to use DMR_SW_CPS_V9.00.09.200.iM(EM5) - isn't support H series
Cable for HP785 is PC152 (clear USB only w/o TTL chips).
Pinout of programing cable in attachment.
dazey77
Yes, PC152, havent pulled mine apart or probed it to see the pinout but the connector looks like it has chips in (due to size) but perhaps it doesn't
The CPS range is completly different for the HP series (as it is different again for the PD3, BDs etc). the v9 is only for PD6-9, MD7 and the repeaters.
