CPS froze while programming
dasnps
I just about finished reprogramming my XTS2500 went to write to the radio. When I did, it started off like normal, but never progressed past the "verifying if device can accept codeplug" part. The radio says program mode on it, and the CPS is not responding and it's been about 40 minutes. An y ideas or did I just wreck my radio?
DonnieDog
Elizabethton, TN
If you saved the codeplug before trying to write or if you have a previous one you should be able to write it again. CPS sucks sometimes.
dasnps
Well, over an hour later, the software finally decided to cooperate and the radio programmed without a problem.
fineshot1
NJ USA (Republic of NJ)
This is usually a pc caused thing - such as an anti-virus program starting up
as you are programming a radio or a spyware scan or other various scheduled
scans. I deleted all of my scheduled scans and now do the updates and scans
manually in order to bypass this happening.
N1SQB
Somewhere On Earth
My saving grace- The "save" button!!!!! I cannot recomend that enough! Hit save every time you do any changes.
Manny
