CPS+ HVN9025J for HT1000?
Rred
I was offered what is supposed to be a genuine Motorola package of "CPS+ HVN9025J" version R06.01.00, programming software which runs under Windows, and probably works for the HT series radios. I'm looking at this to make it simpler to reprogram an HT-1000. Supposedly supports "HT MX LS CDM" series.
Would anyone know for sure, if that's the (probably last) Windows version that works with the HT-1000's?
yaknamedjak
localhost
If you were to do any search regarding HT1000 programming on this forum you would find that the HT1000 can only be programmed with RSS, not CPS, which must be run in a DOS environment. Search HT1000 RSS to find the part number.
Rred
yak, I've done the research, but that's for thinking of that.
There HAVE BEEN some posts saying there is a Windows version that will program these. MOST posts say there is not, but most posts also do not specify version numbers, and they usually reflect the limited observations of random users, rather than the experience of professional Motorola shops that have actually used "ALL" of the variations.
Which is why I asked for a specific answer to a specific question, rather than just random shots at what random users have observed. Or perhaps you are not familiar with the old tale of the three blind men, each describing an elephant, in rather different terms.
And since this CPS manual actually SAYS "HT" on the from cover...there was reason to ask about confirmation of that.
LATA 722
HVN9025J is for the Pro series radios: CDM series mobiles as well as the HT750, HT1250, HT-1550 portables.
Won't work on the HT1000, HT50, HT600, etc. either.
