CPS not allowing me to edit RX/TX on trunk
wa-agent-485
I have a XTS 5000 Model 3, I'm unable to input any RX or TX in the trunked system. It is only giving me drop downs. Is this an issue with the code plug or did I somehow hit a setting causing it to only give drop downs?
crazyboy
NJ
Bring it to the administrator of the system. You can’t program any trunking parameters without the system key. (For a good reason too) You should probably do some research on the subject before you end up with a brick, or worse.
wa-agent-485
Sounds like you've got dropdowns enabled. It's a setting somewhere in the top menus.
Thanks I’ll look into it.
We have the system key. It’s not that we can’t input, it’s just giving drop and only certain frequency’s
wgbecks
NE Wisconsin
Not much informaiton to go on but if you're talking 800 MHz and you've loaded the matching "system key" then check
to see if "rebanding" is enabled. Another possibility might be the Astro 25 Channel ID isn't correct for the frequency or frequencies
that you're tyring to input.
mikewazowski
Staff member
Central Ontario
View/Frequency Options/Enable Frequency Picklists
That will limit you to a drop down channel picker in most places you would normally enter a frequency.
Nothing to do with system keys.
