cps programing question
trent233
I have the motorola programing software and I am trying to program multiple ht1250 radios with the same channel set up is there a short cut to this where I can copy or do I have to enter each channel info 6 different times?
SteveC0625
Northville, NY (Fulton County)
You should be able to shoot the same codeplug into multiple radios if they are all the exact same model number. Repeat: all the exact same model number.
There is no cut and paste, copy and paste, or drag and drop for the Professional Series CPS.
BTW, if you had used the search function, you would have found that this question has been answered many previously.
trent233
Thank you sorry for not doing the search still new to the forum and yes I found out I had to create 2 code plugs 1 for model 2 and one for model 3
