CPS Software do not know how to turn on Programing Setting for CP200
justinryan51
I have the CPS programming software for Motorola Radios and have used it several times on BPR40's however I do not know how to turn on the programming mode on a CP200. A mag one you hold down a side button and turn on the radio. This does not work on the Cp200. anyone know what I'm missing?
SteveC0625
Order of the Golden Dino since 1972
Northville, NY (Fulton County)
Do you have the Commercial Series CPS or the Mag One Series CPS?
justinryan51
Not sure, software came with a radio package i bought used. I do think its the commercial version
SteveC0625
OK, two points you need to know.
First, you must have the Commercial Series CPS to program the CP200's. The MagOne CPS is exclusive to the MagOne's.
Second, if your CP200 has been programmed with a newer version than the one you have (if that's what you have), then your software will not work. The radios must be programmed by the same revision level or newer.
So, first verify what software you have. If you do not have the Commercial Series CPS, please do not ask for it here or on most other tech sites similar to RR or the batboard. It's against the rules and illegal.
Also, do you have the proper cable for the CP200?
