Not sure, software came with a radio package i bought used. I do think its the commercial version
OK, two points you need to know.
First, you must have the Commercial Series CPS to program the CP200's. The MagOne CPS is exclusive to the MagOne's.
Second, if your CP200 has been programmed with a newer version than the one you have (if that's what you have), then your software will not work. The radios must be programmed by the same revision level or newer.
So, first verify what software you have. If you do not have the Commercial Series CPS, please do not ask for it here or on most other tech sites similar to RR or the batboard. It's against the rules and illegal.
Also, do you have the proper cable for the CP200?
