CPS Software Version
SFD1117
Shelton, CT
I just had a quick question in regards to the Motorola CPS Software. I know there are several versions of the software. How do you recongize which software version can program which unit without "bricking" the units? I know several people who have had too new of software and have ruined their portables or mobiles. If anyone can try to explain this to me, it would be appreciated. Thanks!
immelmen
Could you be a bit more specific about which software/radios your talking about. Using a newer version of CPS then was last used on the radio should not be a problem. Going backwards is when you may run into issues such as the "codeplug too new" error. There are some exceptions especially with Astro25 equipment where it is best to use the CPS version that matches the firmware in the radio , such as loosing the FPP feature on Astro25 radios when going from CPS 9x to 12x ect, but generally for Astro radios it should be OK.
