CPS zone/frequency editing
Seanugget
Hi, i'm working on a ship at the moment and we are trying to update or frequency lists. i've updated and reworked a list of about 230 channels we use at various rigs and ports. cloning works perfectly fine on all our mounted UHF radios, but when i try to clone to our handheld ones, it doesn't work. not really shocked about that since they are 2 different models. but is there a way to export just the channels from our mounted ones and import them into the list i read from our hendheld ones? i'd really hate to spend another day just to rewrite that channel list again for the handhelds.
Models:
Mounted - DM4600
Handheld - DP4801 Ex
Using MOTOTRBO CPS2 but i also have MOTOTRBO CPS installed
thanks in advance for any helpful tips
nhfdcadet
New Hartford, Ct
if you're using CPS2, just copy and paste everything, you can either do a top level, or copy and paste the zone
nhfdcadet
New Hartford, Ct
1627474879555.png1627474950326.pngnotice that the copy and paste are in two different spots, copy the zone itself, then paste it to the Zone dropdown.
ALSO if the zone has the exact same name, itll overwrite, which is what it seems like you want it to do, so make sure the zone is named the same. Otherwise itll just create a new zone.
Seanugget
I find myself in another pickle, is there a way to export/import channels from the CTB2 file into say, excel? i need to make a channel list for my boss in a better layout than that you get from the reports function. need to make a layout similar to this:
Ch. numberDescription/ Ch. nameRx freqTx freqRx PL code/freqTx PL code/freqComment
but going into CPS and scrolling through, picking each field and copy pasting them into word or excel is gonna be painful
