Cps
Devilz311
NJ
I've been using The most recent CPS on Vista with no problems at all......
mancow
N.E. Kansas
there are different CPS packages for different radios
The current Astro25 CPS is Vista compliant.
Devilz311
NJ
I have Professional CPS, R06.10.04 on a Vista Laptop with no problem.
immelmen
xts3000/astro saber/spectra CPS is also now compatible with vista as of R05.03
RocketNJ
Pequannock, NJ
Is there a version of the CPS that works with Vista?
Thanks,
CPS for which model radio?
A trick I have done on some versions of CPS to get it to work is right click the setup.exe and go to properties. Choose compatibility tab and set it to run in compatibility mode for Windows XP. This should allow it to be installed.
Once installed do the same for the program exe file.
Hope this helps!
HT and EX series. I just ordered Vista Home Prem. x64 with a new system.
