Craig - Tower 175
realgeo
Murray, NE
Good afternoon!
Tower 175 is confirmed as being Craig. As I sit just off Main St. in Tekamah, NE, I can hear the site with just a short wire touch the center pin of my 396XT's BNC connector.
Here's the data from Pro96Com, which fits with what others observed about Jones Creek. Curious that it's on the same CC as Plattsmouth and shares the AC with Falls City's CC!
In the mobile setting, I started getting this site reliably on HW75 just north of Nashville, NE.
FileVersion:7
-TowerInfo
#This section is here for information only. With the exception
#of the Call Sign(s), This data is not Read back into the program at all.
System ID : 144
System Name : Nebraska Wireless Interoperable Network (N-WIN)
WACN : BEE00
Tower Number (Decimal): 175
Tower Number (Hex) : T014B
Tower Description : (null)
Control Capabilities : Data,Voice,Registration
Call Sign(s) : CHANGEME
Timestamp : Sun Feb 26 14:37:39 2012
-Tables
#Format: Table ID,Base Freq,Spacing,Input Offset,Assumed/Confirmed,BandWidth,Slots
00,851.00625,0.00625,-45.00000,"Confirmed",0.00625,1
01,762.00625,0.00625,30.00000,"Confirmed",0.00625,1
02,851.01250,0.01250,-45.00000,"Confirmed",0.01250,2
03,762.00625,0.01250,30.00000,"Confirmed",0.01250,2
04,150.57500,0.00250,-4.38250,"Confirmed",0.01250,1
05,149.00000,0.00250,0.00000,"Confirmed",0.01250,1
06,161.00000,0.01250,0.00000,"Confirmed",0.01250,1
-Frequencies
#Format: Channel,Usage,Frequency(/Slot),Input Channel,Input Frequency(/Slot),Input Explicit(1/0),Hit Count
"06-0703","i",169.78750,"06-0703",169.78750,0,1
"06-0942","a",172.77500,"00-0000",851.00625,1,0
"06-1026","c",173.82500,"06-0320",165.00000,1,0
-Neighbors
#Format: TowerID,TowerIDHex,System ID,Channel,Frequency,Tower Name
165,"T0141",144,"06-1021",173.76250,"Jones Creek"
166,"T0142",144,"05-2635",155.58750,"Norfolk"
174,"T014A",144,"05-2764",155.91000,"Humphrey"
I've submitted this to the DB Admin for processing.
73
realgeo
Murray, NE
Hey, AVSFAN!
Thanks!
I was glad you underscored that new tower in your post yesterday - gave me a reason to be out and about on such a GLORIOUS "winter day" in Eastern Nebraska!
It's rather curious that Craig and Plattsmouth were assigned the same CC frequency.
On HW75, Plattsmouth faded out quite nicely at Nashville while Craig grew in strength as I traveled farther North.
Coming south on HW77 from Oakland, the Craig tower "ran out" at the hill-top weigh scales north of Nickerson, but Plattsmouth began being reliable between Valley and Waterloo.
I've also been trying to re-acquire Falls City to see if any changes have popped-up there.
73
realgeo
Murray, NE
One more observation about Plattsmouth and Craig...
In the original RFP Attachment D document, Both Craig and Plattsmouth were assigned a frequency of 173.0750.
Obviously this wasn't the channel that was used, but even back then, there was a plan to use the same CC at these two sites.
73
The Falls City site should be up. Heard on Thursday or Friday NPPD workers doing range testing. One was in Pawnee City using the Fall City tower.
The Plattsmouth tower has a good foot print. I can get it full scale here in Elkhorn and I live in a hole. I can barely receive Dodge county SO Disp.
tfhphoto
Sioux City
Impressive! Picking up the Craig site here in Sioux City on a handheld hooked up to an above average mobile antenna.
KF0SKV
Northeast Nebraska
73
My question would be when ducting season kicks in, which is very soon, could there be a possibility that that Craig and Plattsmouth towers may not play well together? Or will one of the towers get a control channel moved to reduce the possibility of interference?
realgeo
Murray, NE
Hey, Rich!
That's a _VERY_ good question, because that's a very likely scenario with the towers being only 61 miles apart, as the crow flies.
Most of the problem will be in the "battleground" area where the two coverage circles intersect and interfere the most with each other.
I'm sure that the system designers and planners have taken this into consideration!
73
