Crawford County - Fire Dispatch
jtajk1995
Van Buren, AR
Alright, I will try to keep this simple as it is really starting to frustrate me.
Equipment:
(1) RS-PRO2040 (Negative results)
(1) BC7 (Received CCFD on last night partial calls, without Toneouts)
(1) RS-PRO2054 (have not tested)
Issues:
Trying to receive County FD Dispatch (Overall Negative Results)
Antennas:
BC7: Rubber Ducky (In Living Room)
PRO2040: Double Load Scanner Antenna (RS used to sell) attached to a ground plate in the attic. Receiving VBPD and VBFD, no problem.
REQUEST:
1: Could someone in the local area assist me with setting these up correctly? I've got trunking capability on all of them. Just getting nothing but GARBLE on trunking.
2: Do I have the correct frequencies?
3: I'm also trying to identify the correct tones for the county as well.
Thank you in advance.
03msc
RF is RF
The Natural State
Based on the db it looks like they are conventional NFM. I do see one NXDN freq listed as district 1 but the rest show to be regular analog NFM.
Just verifying that’s what you have programmed? Based on the db they use a split tone so your scanner would need 100.0Hz on the rx CTCSS. Correct?
jtajk1995
Van Buren, AR
Thanks, everyone for the quick help.
Was just able to catch District 3 get toned out. It is the 155.145. Just as I figured it uses the triangle repeater antennas in the county to page everyone out.
Now I just need to gather the Tone freqs so I can catch those and plug those in.
