myspacebarisbroken
Audio feeds can actually be "saved" and played with programs such as winamp without having to use radioreference! This way you can create vast lists of feeds and have the ability to switch feeds with a simple click.
1) Go to the page of the desired feed and under "Player Selection" select winamp.
2) Left click the speaker icon and select "save target as..."
3) Then name the file and save to your PC.
4) Next, start winamp and select "Import playlist from folder..." and select the folder containing your saved audio feeds.
5) Once this is done, you will have a list of the saved feeds and can enjoy switching between feeds with a simple click.
Windows Media Player can also use the feeds in a similar way.
Enjoy! Questions and comments welcome.
