Crofton
elmanc
I have a pro 106 lm in crofton why cant i here PG on my 106 im not happy with this scanner I might b doing somthing wrong. i also have a pro 97 an i can here more on the 97 then the 106 whats up with that ,, not sure i mean i have the radio shack wire hook up that take just 5 sec to download to 106 it is easy.
ka3jjz
Wiki Admin Emeritus
Bowie, Md.
This is nearly impossible to diagnose correctly without seeing the programming (I'm not a RS fan...). Anyway, you didn't say what software you are using, but if you were to take your programming file, compress (zip) it, then attach it to your message, others that use the same software you are can look at what you've programmed. I suspect it's a programming issue, but without seeing the file, it's not possible to say for sure 73 Mike
