Cross-Band Repeater
jonwienke
More Info Coming Soon!
VA
I'm looking for an economical mobile radio that has a cross-band repeat function. Good selectivity is desirable, as I live near a pager transmitter that spams some radios across most of the VHF band. Interested in hearing user experiences using cross-band repeat, good, bad, and ugly.
DMR capability would be a plus.
robertmac
As in amateur radio bands or outside? Only know amateur from 2m/70cm, or 70cm/2m. FT-8900 works very well and can be set up in hyperscan, FTM-400, Icom 2820. Although I have not used Kenwood mobiles, they are work very well with the 710 having a couple of different ways to cross band repeat. Settings with Tones help avoid some interference.
Encouraging proper use of two-way radio spectrum including CB.
kayn1n32008
ØÆSØ
Sector 001
Cant beat the TM-V71a or TM-D710. Kenwood has the best implementation of cross band repeat of any of the major ham manufacturers
Thunderknight
Bletchley Park
Except the V71a sends the CWID on both bands. If you are crossbanding 2M to 440 (where 2M is the repeater and 440 is the HT side) you don't need to auto ID on the 2M uplink (as long as you voice ID with your transmission). However it does every 10 minutes, blinding sending the ID on the repeater input and annoying everyone. We had a public safety event last year where someone had one and we had to get them to shut it off their crossbanding because it was interfering with the repeater.
jonwienke
VA
This will mostly be used for a business application, not HAM. So a radio that can transmit outside the amateur bands is required.
Thunderknight
Bletchley Park
Not just transmit outside, but is part 90 type accepted (if you are in the US).
I would suggest looking at a commercial mobile with a Pyramid or Vertex vehicle repeater if you want a robust way to do it.
kayn1n32008
ØÆSØ
Sector 001
Agreed. This is the route to go, Unless you want to spend bucks on an APX/XTL paired with a Futurecom repeater...
More expensive than the Pyramid, but cheaper than the APX:
You can do this with two Kenwood NX-5000 mobiles, even with a single control head.
Not cheap, but it's Part 90, Part 80 and will do amateur just fine.
If it was me, I'd do the Pyramid.
jonwienke
VA
The repeater will not see heavy use. Are there any options that would fit in the "budget and entry level" category that would work reasonably well with a pager transmitter nearby?
Pyramid. I've seen them on e-Bay for $30 or so. Programming software is/was free on their website. Programming cable is easy to roll our own. Good support on the product. Well proven in the industry.
Pyramids are also sold under the Ericsson brand name, so search on that while you are at it. There's usually a bunch of them on e-bay at any given time. I've been tempted to pick one up myself, but then I'd have to get a UHF portable...
jonwienke
VA
The price is attractive, but the power output is a bit less than I'm looking for. Some tests have been done with a 5W HT, and it handles the interference OK but additional power would be useful. Anything similar to the Pyramid in the 25-50W range?
A mobile with cross-band repeat and decent selectivity is all that is really needed.
kayn1n32008
ØÆSØ
Sector 001
Why? if you are only using a portable, transmitting from the mobile at 5-10 times the portable power output is kinda pointless.
The only Mmobile repeater that offers more than a couple watts of output power is the Futurecom DVRS that transmits at 10w before the duplexer, but it MUST be interfaced to either a XTL5000 or APX mobile with the DVRS flash option.
Really, you are not going to find a "cheap" dualband LMR radio capable of crossband repeat with out making your own from two mobiles...
Vertex, Kenwood and Icom all make mobiles that have everything you need to interface the radios together on a DB-9/15/25 on the back of the radios.
There is a reason that Pyramid and Vertex mobile repeaters are so low powered...
jonwienke
VA
That is an incorrect assumption.
Users will be a mix of mobile and HT.
Using a cross-band capable HT as a repeater was done as a test.
Sounds like to do this on a budget, you have two options:
1. Buy an old mobile that has the correct interface to roll your own setup.
2. Find a $130 Chinese mobile that does this, receives FM broadcast, makes toast, and washes your car.
jwt873
Woodlands, Manitoba
For an old mobile, I'd look for a couple of older used commercial mobiles on eBay, (Like the Motorola Maxtrac or Kenwood TK series). I'd get one UHF model and another for VHF. Then, I'd link them with a cheap repeater controller.
bharvey2
Though I've never use one, I believe Wouxun makes a dual band mobile radio that can do cross band repeating. I recall reading that it is Part 90 certified too. (or as Part 90 as some of the CCR get.) Wouxun UV920 P is the model number. I recall Powerwerx rebadges this radio too.
12dbsinad
I'd just build it with 2 mobiles of the same model. You can use a inexpensive controller like a Midian. I'd stay away from any cheap china radios.
I've built many out of using Midian controllers. Just flip the switch, and you've got cross band repeat.
