Crossbanding Conventional to LTR through RICK...
Signal-Zero
I make sense out of nonsense
Has anyone crossbanded a conventional repeater through a RICK to a LTR trunked system ? Does the RICK delay the audio in order to give the LTR radio time to PTT ?
Signal-Zero
HLN3333B Repeater Interface Communications Kit (RICK) is a device that connects between two mobile radios to construct an intermittent duty radio repeater. The unit can be configured as single or bi-directional, and can be used in single or crossband applications (depending on radios used).
ramal121
Sonoma, CA
There is no audio delay in a R*I*C*K, just straight through. I have done several LTR to LTR extenders using an Easy Link. Same idea and it does not have audio delay. Works OK and if you can access the trunk system usually on the first bang and you tell the users to slow down, it's acceptable comms. I did do a three way extender WITH 250ms audio delay and thought that worked real good. There are still gotchas that may crop up and you'll just have to live with 'em.
