CS 580 new firmware
blackbelter
Today I tried to upload the newly released CS580 firmware 1.10 however the file is not extracting . I followed the instructions with no success. I also verified that all of my window 10 set up are correct.
When I clicked and saved the update the file was not being saved as an exe file.
Perhaps we may need some support on this.
KE5MC
Lewisville, TX
I went and downloaded the 4 files. One is .txt, 2 are .docx and one .bfup.
It was not a quick understanding of the process for me. I will spend some more time with it. My expectation is the bfup might be the image file.
About the most unclear to me update I have run across.
Mike
KE5MC
Lewisville, TX
blackbelt,
I had to make the connection that the updater exe was zipped up and linked in an earlier software update on the 580 page. Once I made that connection the 1st page of the firmware update document made sense.
I was correct that the updater program is looking for files ending in bfup. Verified radio was updated to number referenced in file name. Loaded English file per instruction as if it were a codeplug. Not sure what it did for me but it did not interfere with the codeplug that was loaded.
I did not 'brick' the radio. :D New items in the menus to play with.
Mike
SteveSimpkin
Lancaster, CA
Yes the CS580 Update to 1.1.0 is a bit more complicated than before. Here are the steps needed to update the firmware.
1. Go to: Connect Systems
2. Download the first four files shown. These are: "update_firmware_CS580_V1.1.0.bfup", "ENGLISH", "SAVING THE ENGLISH FILE.docx" and "Updating CS580.docx". Note that the file named ENGLISH has no extension.
3. If you had not performed an update previously, go to the item "Firmware Update Zip Files" (4th from the bottom) and download the "BFP_UPDATE.zip" file. This ZIP file contains the program files needed to update the firmware. Ultimately you will unzip these files into the "C:\Program Files\BFDX\BFP_UPDATE" folder (using the instructions in the next step).
4. Follow the directions in the "Updating CS580.docx" document. This will allow you to update the firmware to V1.1.0 using the "update_firmware_CS580_V1.1.0.bfup" file downloaded previously.
5. Follow the directions in the "SAVING THE ENGLISH FILE.docx" document. This will allow the CPS software to communicate with the CS580.
The new features are described in a "New Features" document located on the following page. This page also has the SC580 Users Manual and CPS Manual.
Connect Systems
blackbelter
I appreciate the explanation, however something is clearly wrong that a simple firmware update should be this complicated. My other concern is that per CS web site the update has not been verified or tested as it cautions the end users that they are not sure that if it works?
Help me understand this please .
The updates should be part of the BFP-CS 580 to be downloaded as not often an end user will be willing to spend hours on updating firmware.
Thanks for your time.
SteveSimpkin
Lancaster, CA
In my experience, firmware updates are rarely simple. The process is not quite as bad as my description made it out to be. I was trying to be thorough and I often come across as too wordy. If you had been through this before (as I had) the only new item is step 5.
Regarding testing. The manufacturer, BFDX, did test this firmware at their development lab. The distributer, Connect Systems, performed a brief test at their facility and then posted it on their website so early adopters could start using and testing it. As such I would advise anyone who does not want to participate in this "testing phase" to wait a few weeks until others have verified there are no glaring bugs.
My point of view is that these are amateur radios marketed to ham enthusiasts and are not general consumer products. If you are looking for a radio that has been exhaustively engineered and tested before being sold in the marketplace, these low-cost radios are probably going to dissappoint you.
I own a CS580 and a DG-77 portable and am very happy with both of them. YMMV
blackbelter
Thanks for your response, I also enjoy my CS 580 and would have liked to enjoy the new features , however i will wait till the process gets more refined.
Thank you!
