CSP ID's
Killingly CT
I have a couple ID's i have that i still havent been able to figure out.
7280 - heard what sounded like troop K cars on there only because i heard it while i was listening to 868.9125 and heard them say something about parum rd.
1104 - still hear stuff on there once and awhile while im in the norwich area, usually while they are running
reg numbers.
before anyone asks, i have these programmed in the memory, not on ID search.
cg
Connecticut
If you watch a data channel decoding program, you will not see them because they are not CSP TGs. You are hearing traffic from other legit talkgroups. It is an issue with the scanner. Put a second scanner on the regular TGs and you will match them up.
chris
Killingly CT
ok thank you... that is one thought that had crossed my mind... i recently had the scanner worked on and i never had that problem before i sent it out.. i had the scanner repaired for a receive problem.. seems they fixed the receive problem and caused another... ha ha i thought only auto garages did that (fix one problem and cause another).
