CSP Troop H
N1NIJ
Hello, all!
The other day I programmed Troop C and Troop H in separate scan lists (TRX-1 and EZ scan).
When Troop H is heard the display will show Troop H disp. , Conn Land system , but also “Troop C simulcast“ . Did I program properly? Why the Troop C part?
CT
Hello, all!
That's likely the site you are receiving the signal from.
The database should confirm that .
(y)
W1KNE
Owner ScanNewEngland.
Taunton, MA
It means you're receiving the signal from the Troop C Simulcast Zone.
Cheeseburgers
I actually just started monitoring with a PSR-800, very impressive so far.
But yes, the doc is right, youre listening to Troop C Simulcast (site), you can select in the options to show VC/CC, Site ID, TG ID and Radio ID
N1NIJ
Thanks all! Seems I need to learn how to interpret the database info, such as what doc posted for me to look at. First , I’m on the edge of Tolland county (Troop C) and can hit a 9 iron into Hartford county (Troop H). 1: I know Troom C and Troop H are two different simulcast sites. 2: I didn’t realize that Troop C zone will pick up and forward Troop H zone transmissions.
Am I starting to understand this? Perhaps someone can further explain this to me or recommend something in the Wiki that covers the topic.
Thanks much!
dimab
CT
Thanks much!
zones have neighbor zones, so they will carry the neighboring traffic. additionally - when a radio comes into a different zone (affiliates) from a far away zone, lets say Troop L radio rolls into Troop C area, Troop C will start broadcasting Troop L traffic while that Troop L radio is there.
CT
Thanks much!
Look in the Wiki for 'Trunking Basics'.
If you have questions, just ask!
Enjoy!
nhfdcadet
New Hartford, Ct
thats IF the talkgroup is enabled on that subsite. Some are statewide, others are limited to certain districts, like some may be just eastern district, or just western district. I.E. I can't talk to NWCTPS on the troop E site, I get bonked.
I don't know if the troop talkgroups themselves are restricted the same way, or if it is just affiliation based.
