CSV import, how to convert spreadsheet A column?
Anderegg
Enter text in this field
San Diego
I am trying to import RRdb for a system that is 3600 baud, into my talkgroup list for my counties new 9600 system. I can work the import, but I would have to manually convert a thousand talkgroups with a calculator and Windows Notepad. Anyone know how to apply a divide by 16 to every talkgroup decimal in the A column of a Google Spreadsheets? Would like to have my G5's programmed prior to talkgroups being moved onto the new system next month...RRdb always lags a month behind real world changes.
Paul
GTR8000
NY/NJ Database Guy
BEE00
Put =A1/16 into the first cell of an empty column, then drag the formula down the entire column. You can then CTRL+C copy that new column of TGID's and use CTRL+SHIFT+V to paste the values back into column A. Don't use CTRL+V as you'll paste the formulas back into column A, which you don't want to do.
Anderegg
San Diego
Thank you, it seems to have worked! :-D
I've never used Excel or a spreadsheet before.
Paul
kruser
Well Known Member
W St Louis Cnty, MO
Paul
Yep, spreadsheets can be intimidating! They sure are nice when they work the way you want though.
Glad you got it working and also glad you asked this as I was having the same problem.
bob550
Albany County, NY
You're missing a big slice of life! :) I've used Excel for many years, extensively at work but also at home. It can be an incredible workhorse if you know how to make the best use of it, and is very useful for the manipulation of frequency data in our hobby.
Anderegg
San Diego
Yes, I am now using it to convert my Uniden XT Freescan talkgroups to 9600 as well. :-D
Paul
